Printing time uncerteinty
bielend
(@bielend)
Miembro
I have a problem with printing time. There is very small difference in printing time after I change leyer height. I have prepared a printout with leyer heigt of 0.2 mm slicer shows it takes  7 h 58 min, if I change leyer height to 0.4 time is reduced only to 6 h 57 min. When i choose i3 MK3S printer with layer of 0.35 the time is 9 h 28 min, with layer of 0.2 time changes to 12 h 3 min.
I wonder why the time difference in Prusa XL is so small, I checked the speeds and nothing changes. I changed only the layer height, do you have any idea why it works like that?
Respondido : 26/09/2025 8:20 am
Pe3d
 Pe3d
(@pe3d)
RE: Printing time uncerteinty
Thats because you have to Set the Maximum Filament flow. You can See the difference if you switch to Speed view in the slicer.
https://help.prusa3d.com/article/max-volumetric-speed_127176
Respondido : 17/12/2025 5:34 pm
BaconFase
(@baconfase)
That's way too broad of a question for anyone to really answer without giving us two project files to compare for specifics.
Respondido : 18/12/2025 6:32 am
