Printing large curved fascia in ASA-CF
vahid
(@vahid)
Mitglied
my client needs a large fascia printed in ASA-CF. Can anyone help with a prusa profile for this material? We prefer using Bambu labs but open to other companies provided the finish is the same as the bambu labs one. I have attached my whole config bundle. Can someone please have a look and let me know what I would need to tweak. So far i have a tiny layer separation issues, one minor (but noticeable ) layer shift and one major layer shift (8-10mm jump). This major shift also causes the extruder head to crash into the parked extruder . TIA
PrusaSlicer_config_bundle
Veröffentlicht : 27/11/2025 4:13 am
jan.d.slay
(@jan-d-slay)
Hi Vahid.
I only have experience with ASA on the Bambu Lab X1C and not yet with the Prusa XL, but maybe this will help you.
First of all, thank you for your configuration file.
  1. I don't know how large and detailed the printed part will be, but I recommend printing with a 0.6 mm nozzle. The larger the component you want to print, the longer your printer will take and the smaller the nozzle will be.
  2. You set the first layer to 0.2 mm. This is not good for ASA. I had the first layer pressed onto the print bed at 0.1 mm plus print bed adhesive.
  3. I would also halve the solid layers at the bottom.
  4. Using only a perimeter in the first layer also improved adhesion for me.
  5. In my opinion, the speeds for infill and perimeter are much too high.
  6. Since I don't know what your workpiece looks like, I can't judge whether you have many bridges and overhangs. If not, I would completely forego cooling.
  7. Did you get your specifications in the profile from the Bambu Lab Studio from the ASA-CF profile?
  8. Do you have a Prusa XL with a closed chamber? If not, this could be another reason why the component is warping.
For small printed parts, printing without a housing is not a problem. The print bed emits enough heat to prevent the material from cooling down too much.
But the further the extruder is from the print bed, the faster your molten filament cools down. This causes the material to warp.
Print speed, lack of enclosure and cooling fans naturally contribute to your print not turning out well.
My printables
Veröffentlicht : 03/12/2025 9:50 am
