Print gcode sliced for Tool1 with Tool2?
Is this possible? If so, how? This should be in the manual, but I couldn't find it.
Opublikowany : 06/09/2023 12:28 am
1 ludzie polubili
RE: Print gcode sliced for Tool1 with Tool2?
I'd also really like to know whether this is possible. It would be a massive time saver.
Opublikowany : 13/11/2023 8:17 am
If you are running the latest alpha firmware then you can change the tool you want to use at the start of the print, regardless of which one it was sliced for.
Opublikowany : 13/11/2023 11:48 am
