Pressure Advance or under extrusion
I printed this box from Printables to keep my XL 5T spare part in. It isn't a bad print by any means. I think the text is either under extruded or pressure advance needs adjusted. I have attached a picture and if you look closely you will see the little pin holes in the text.
Postato : 20/08/2024 7:28 pm
It looks like the designer optimised it to be printed with a different sized nozzle ... what are you using?
Postato : 21/08/2024 12:50 am
Topic starter
answered:
RE: Pressure Advance or under extrusion
I am using a 0.4 nozzle.
Postato : 21/08/2024 2:29 am
Hmmmm. Early XL's shipped with 0.6 nozzles.
Postato : 21/08/2024 9:16 am
Topic starter
answered:
It is not an early XL and it is definitely 0.4 nozzles.
Postato : 21/08/2024 9:43 am
I didn't mean to mislead; what I meant was that it's possible the part was designed for the early XL's defaults.
Postato : 21/08/2024 9:49 am
