Multiple M600s on the same layer
I'm attempting to do a '4 color' print on my 2 head XL, the design is simple enough and in Prusa Slicer 2.8.0 (that just came out) I can see that I can put a change filament on a layer and select the correct toolhead, however it seems if I add Tool 1, then I add Tool 2 to the same layer, that it simply overwrites the Tool 1 change. I could probably work around this by doing a second change one layer later for Tool 2 but that's only possible due to this particular design. Is there a workaround or trick to do a 'change all' or multiple tools at the same time?
Postato : 28/06/2024 3:15 am
