RE: Help with finish on support areas
Should probably zip and upload your 3mf project file so we can have specifics to dig through. This looks like a normal underside of a supported area with a non-zero z contact distance.
Generic advice based on guesses: if you're going for the 'perfectly supported underside' type of print that a multitool XL is good at then start with the Breakaway print settings and PETG for the supports.
Posted : 17/06/2025 12:49 am
