Changing height of the first three layers when using different nozzles
Jan Suchánek
(@jan-suchanek)
Membre
Hi, I have a bit of a problem. In extruder 1, I have a 0.4 mm high-flow nozzle, and in the others, 0.25 mm. I need to print an object so that the first two or three layers are printed with nozzle 1 at a higher speed and, most importantly, with a layer height of 0.2 mm. The remaining layers should then be printed with the 0.25 mm nozzles.
I’ve set everything up, but I can’t change the layer height. It won’t let me go above 0.15 mm because the profile is set to “5T 0.25 nozzle / 0.12 mm quality.” Even if I import the bottom part separately, the top automatically snaps to the build plate and can’t be moved higher.
Is there any tip on how to achieve this? Ideally, I’d like to assign a different print profile just for the bottom part.
Publié : 23/10/2025 6:49 am
Jan Suchánek
(@jan-suchanek)
Membre
RE: Changing height of the first three layers when using different nozzles
It works now, I have to turn on automatic extrusion width counting in advanced settings. But still can´t set first layer to 0.3mm. But that is not problem, I set second layer to 0.3mm and that is enough to me.
Publié : 23/10/2025 11:00 am
BaconFase
(@baconfase)
The slicer does a bunch of checks that 'randomly' change from version to version. At one point (maybe currently as well) having multiple nozzle sizes of different min/max layer heights set in the Printer Settings would prevent some slicing. The workaround is to have all the min/maxes set to the same for all nozzles regardless of size and 'compatibility' to said layer heights.
Publié : 30/10/2025 12:39 am
Jan Suchánek
(@jan-suchanek)
Membre
I have this setting, but still get "First layer height can´t be larger than nozzle diameter" error with first layer height set to 0.3mm even if this layer is printed with Extruder 1 which has 0.4mm nozzle...
Publié : 03/11/2025 1:46 pm
