Can't print filament, but it's loaded
Kateřina B.
(@katerina-b)
Membre
Hello, I am asking for help with my printing problem. I have successfully loaded the filament, it goes out without any problems while loading. But when I start printing, nothing comes out of the nozzle. Do you have any recommendations or experience?
Thanks a lot!
Publié : 06/07/2025 1:30 pm
Is this a new printer that has never worked properly or one that previously worked which has developed a problem?
Publié : 07/07/2025 4:18 am
Kateřina B.
(@katerina-b)
Membre
RE: Can't print filament, but it's loaded
It worked well. The problem appeared when I changed the filament. Thank you!
Publié : 07/07/2025 4:40 am
In case it's a filament problem try a different filament.
It's unusual these days but not impossible that the filament diameter is incorrect.  Measure the diameter in several places and average - is it 1.75mm?
If not, enter the actual diameter in the slicer when using that filament and adjust the extruder idler pressure accordingly.
Publié : 07/07/2025 6:52 pm
