2 Color Print, MM painting - Single layer prints in wrong color?
8bitfusion
(@8bitfusion)
Hi all, I'm encountering an issue with this 2 color print. I'm using multimaterial painting. A single layer's perimeter and infill is being done in the wrong extruder color, and then it immediately changes back to the correct tool afterwards, resulting in a single line that stands out on the print. Otherwise, the print's color has no issues. It oddly changes boundary between the two colors for this one layer, then immediately reverts back to the previous |^| shaped boundary above it.
Does anyone know what might be the cause of this?
Opublikowany : 13/02/2024 9:07 pm
8bitfusion
(@8bitfusion)
RE: 2 Color Print, MM painting - Single layer prints in wrong color?
Another look at that layer.
Opublikowany : 13/02/2024 9:09 pm
Could you please attach the Project file that you are using for this print?
Save the project file, then ZIP Compress the file and attach the zip file
Regards Joan
Opublikowany : 14/02/2024 9:24 am
