XL reboots on Z-Axis Calibration
Wolfgang
(@wolfgang-7)
Hi ,
I've assembled an Xl and the first run was fine. The first object printed was the gear example on the stick which started , ended up with shifted layers.
The z-axis calibration end up in reboot of the printer.
The attached files are the first printed oject and the video of the calibration.
The chat with the supprt ends up with the belt tension check , which is fine , but the calibration is still not successful
Any suggestion to do additional checks ?
Calibration Video
Best Answer by Wolfgang:
Hi ,
the left side pulley was loose.
Due to the fact that this was a semi-assembled part , it was not checked by me.
So this case is closed and the printer is working now.
This topic was modified 1 year temu 2 times by Wolfgang
Opublikowany : 19/11/2024 3:49 pm
Wolfgang
(@wolfgang-7)
XL reboots on Z-Axis Calibration / First Printed Object
Opublikowany : 19/11/2024 3:55 pm
Wolfgang
(@wolfgang-7)
RE: XL reboots on Z-Axis Calibration
Hi ,
Opublikowany : 22/11/2024 1:29 pm
2 ludzie polubili
