XL dimensions
Jeggo
(@jeggo)
XL dimensions
Would somebody be so kind to measure the distance between the upper 3030 aluminium extrusions (the upper arms)?
I am building the enclosure https://www.printables.com/de/model/610843-enxlosure-minimalist-and-printable-prusa-xl-enclos
As I sourced all materials on my own, I used the drawings to cut the acrylic parts. But the front doors will not fit (appr. 4mm too wide). I modified almost every part, but maintained the outer dimensions. So I have no idea were the problem is.
Napsal : 16/02/2024 7:23 pm
EastMemphis
(@eastmemphis)
RE: XL dimensions
I have a pretty accurate model of the XL on my printable page. Try that. You should be able to derive any measurements you need from it.
https://www.printables.com/model/762684-prusa-xl-model
Napsal : 16/02/2024 8:28 pm
2 lidem se líbí
Jeggo
(@jeggo)
RE: XL dimensions
Thanks for the model. It has the same dimensions as the real one. So the drawing of the enclosure must be wrong.
Napsal : 16/02/2024 8:34 pm
1 lidem se líbí
EastMemphis
(@eastmemphis)
I think you'll find my model is pretty close to 1 mm accuracy. If you find anything out of spec, let me know and I'll correct it.
I don't know if this is possible or not but that enclosure has been around for a while. It could very well be that the specification has changed in the ensuing time.
Napsal : 16/02/2024 8:57 pm
