X/Z linear rail bearings?
8bitfusion
(@8bitfusion)
Hi all. I made a mistake and lost quite a few bearings from my Z axis rail which has the piece which holds up the bed. Is anyone familiar with the size of the bearings in that Z axis housing?
I do not have calipers to measure precisely.
Best Answer by 8bitfusion:
Sorry, i found a wrong ball bearing on the floor somehow - they are actually 2.48mm
Postato : 23/01/2026 2:37 pm
8bitfusion
(@8bitfusion)
Update, they are 3.95mm diameter. Had to buy a set of calipers, probably needed them in the future at some point.
Will also be using this tool to reinsert!
https://www.printables.com/model/1409176-linear-rail-bearing-carriage-insertion-tool-prusa/files
Postato : 28/01/2026 4:22 am
8bitfusion
(@8bitfusion)
RE: X/Z linear rail bearings?
Postato : 29/01/2026 1:27 am
1 persone hanno apprezzato
