X axis shift when using spool join.
Mikemike85
(@mikemike85)
Hi all, I have been noticing an issue when using the spool join feature. Print is running flawlessly and once it starts the spool join the next tool head is 5-7mm off on the X axis. The print will continue on and print just fine, only 5-7mm to the left of where it should be.
I have a small print farm and am currently running 5 Prusa XL dual head printers. I love the idea of the spool join feature due to less waste on filament and less spool change overs.
I have named them all Prusa XL 1 through Prusa XL 5. Prusa XL 3 seems to run the spool join feature with no issues. Prusa XL 5 had a tool crash this morning while changing from T2 to T1. The tool was docked and there was no visible issue that I could see.  When I fixed the error, it changed over to T1, and it was about to start printing 5-7mm to the left again. Prusa XL 1 and 2 completed their spool join with no issues but were both printing 5-7mm to the left as well. Prusa XL 3 completed the spool join with no issue. I figured I wouldn't push my luck and manually changed Prusa XL 4's filament out of fear I would lose the print.
Prusa XL Dual head, running Sunlu PETG, .4 nozzles, 50-hour print cycle. Prints are nice and clean, just running into a Spool join issue.
I did calibrations prior to starting this print. Is there something I am missing or is this possibly a firmware issue?
Napsal : 25/11/2025 2:40 pm
jan.d.slay
(@jan-d-slay)
Have you tried the new firmware version 6.4 yet?
Napsal : 27/11/2025 7:13 am
Mikemike85
(@mikemike85)
RE: X axis shift when using spool join.
Just pushed the newest firmware update today. We shall see if that fixes it.
Napsal : 27/11/2025 5:45 pm
1 lidem se líbí
