What size and where can I get more of the spring t-nuts
mdressel
(@mdressel)
I want to add a few things using additional t-nuts but it isn't clear what exact size they are. The only thing listed in the manual is M3nEs which doesn't match anything in Google except Prusa. The naming implies 3mm to me for something, but I am not sure what. When I measure the size of the extrusion it appears to be 30mm. I really would like the spring loaded nuts if possible.
Opublikowany : 27/12/2023 11:40 pm
Work the other way around:  Buy whatever you can get, measure them, and design your print to fit them.  *If* you can make the size parametric it's a win-win when next supply is short and you have to adapt again.
Opublikowany : 28/12/2023 12:06 am
Marc
 Marc
(@marc-9)
RE: What size and where can I get more of the spring t-nuts
You can buy them from Prusa: https://www.prusa3d.com/product/psu-holder-m3ne-2/
Opublikowany : 29/12/2023 3:33 pm
1 ludzie polubili
james.c66
(@james-c66)
They are M3 spring t nuts for 3030 extrusion. “M3” refers to the screw thread. Most t nuts for 3030 start at M4 and go to M8, which is why they are hard to find. A more common version of spring t nuts is a little longer and uses a spring loaded ball bearing for retention. I have had little luck finding them, however, outside of Prusa. If you can use a larger screw >=M4, then they are easy to find.
Opublikowany : 14/01/2024 4:38 pm
1 ludzie polubili
EastMemphis
(@eastmemphis)
Here's a link to Amazon for M4 Spring nuts. I used these in a project and they work great. M3 is a bit too small for even lightweight objects so if you're adding on to your XL, I suggest going up a size to the M4.
https://www.amazon.com/gp/product/B0CG4TKJJJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Opublikowany : 14/01/2024 4:57 pm
2 ludzie polubili
jprince
(@jprince)
I know this is an old thread, just wanted to add that Misumi also carries them.  Made for 3030, A little larger than the original, works fine.
Misumi M3: HNTAP6-3
Misumi M4: HNTAP6-4
Misumi M5: HNTAP6-5
This post was modified 1 year temu by jprince
Opublikowany : 11/04/2025 5:39 pm
1 ludzie polubili
