Toolhead LED flickering
Robert
(@robert)
When I look at the light from the toolhead LED, it is constantly flickering instead of lighting continuously. It happens regardless of whether it is actually heated or not. Do you have similar experience? Can the flickering be avoided?
Napsal : 26/08/2024 9:27 am
Erik
 Erik
(@erik-3)
RE: Toolhead LED flickering
I haven't noticed flickering on mine. If you swap tools, do they all flicker?
Napsal : 26/08/2024 5:12 pm
Robert
(@robert)
yes, all 5 tools are flickering, seems to me there is almost no difference between them. It is not visible too much when the tool is moving, but highly visible when the tool stays at the same place or is moving very slowly the same direction.
Napsal : 26/08/2024 6:06 pm
SailorEric
(@sailoreric)
Yes, mine is doing the same. Have an email in to support but no answer yet.
Napsal : 26/08/2024 7:46 pm
SailorEric
(@sailoreric)
I just heard back from support. They have decided that can be normal operation. One more strange erratic thing this printer is doing.
Napsal : 26/08/2024 8:36 pm
Robert
(@robert)
Cheap Chinese flash lights do the same. 🙁
Napsal : 27/08/2024 5:49 am
BogoRin
(@bogorin)
Both of my toolheads are acting the same. I don't remember this flickering at the beginning (printer about 6 months old).
It looks more like a PWM issue rather than a hardware one. Or a combination of them...
Napsal : 03/09/2024 9:22 am
BaconFase
(@baconfase)
10 month-ish old XL. No tool LED flickering whatsoever, but I've only recently started having them on.
Napsal : 03/09/2024 3:49 pm
jensileinchen
(@jensileinchen)
Hey Folks, same here XL printer from 4.2024 - booth heads LEDs are always "flickering" --- is there still no solution available ?
Napsal : 08/10/2024 10:09 am
Brian
(@brian-12)
The heads I use the most flicker.  So some do some don't.
I only turn the lights on if I need to look at something.  No point in running them all the time.
The issue I can see is that I dont think they are easily replaced as they look integral in the print head.
I contacted support months ago and they basically said it still works and there is no way to change it without replacing the print head.
So I just moved on.  Like I said no point in having the light on the whole print, it's just wasting energy.
Napsal : 08/10/2024 12:02 pm
m_a_s
(@m_a_s)
For what it's worth my XL's toohead LEDs have started to flicker.  Had it since Nov. of '23.
I would say it has gradually started doing this since a few months ago.  But now it's very noticeable.
Napsal : 16/02/2025 8:00 pm
Ro3Deee
(@ro3deee)
As the toolhead LED starts to flicker more and more, the extruder motor error is coming soon.
By cleaning the connectors of the cable-splitter-dwarf with ISO alcohol and a brass brush the flicker goes back to extremely minor to no flicker.
With as it gets heavier and more pronounced, the extruder motor error not screening is coming soon.
Napsal : 14/12/2025 7:35 pm
Ro3Deee
(@ro3deee)
here is a step by step video on how to fix Prusa XL flickering lights and extruder motor not spinning:
cable cover: https://www.printables.com/model/1516970-dwarf-cover-connector-for-prusa-xl-easy-to-remove
nextruder cover: https://www.printables.com/model/810070-nextruder-transparent-front-case-petg
Napsal : 15/12/2025 7:32 pm
1 lidem se líbí
RD
 RD
(@rd-5)
Wow - thanks for this! Just subscribed. This should make it into the PRUSA maintenance instructions or something. Never occurred to me that this thing is like an old Nintendo with erratic cartridges.
This post was modified před 5 months by RD
Napsal : 16/12/2025 2:56 am
Ro3Deee
(@ro3deee)
Gold connectors (no more oxidation and fretting) and a airtight case (so fumes from printing don't get into it to depose on the connectors) should be the proper solution.
Also dielectric grease could help and deoxit, as this is the same problem that plagued MMU2
Napsal : 16/12/2025 6:25 am
BogoRin
(@bogorin)
Posted by: @ro3deee
Thank you for replies.
Indeed I had one occurrence of "motor not spinning" a while ago and immediately after I printed and install the new official connector for toolhead cables. No more motor error ever since but the flickering still in place for both toolheads. It's quite a long time since then. I just started to ignore the problem as long as it have no impact in functionality. Is only cosmetic...
And yes, the redesigned cableholder IS an improvement over the original part.
Napsal : 16/12/2025 6:12 pm
JPMakesStuff
(@jpmakesstuff-2)
Just here to say I have this problem too, the most used toolheads now have flickering issues, I will try the connector cleaning as described...
If in-fact these connectors are getting dirty, such that it affects LED PWM signal or power, I wonder if that's why some of my PETG prints are getting worse quality, as in the heater temperature is not remaining constant?
I'm also curious of the wire itself, moving back and fourth over time, is getting broken internally. I know it's stranded wire which is designed to move, but perhaps flexible PCB/ribbon would be a better choice here?
Napsal : 16/01/2026 2:45 pm
klaus25
(@klaus25)
Yes, if the connectors are dirty or oxidizing, it can absolutely affect:
LED PWM signals (flickering, inconsistent brightness)
Heater power delivery (leading to fluctuating temperatures)
Possibly even nozzle fan behavior or other toolhead functions.
Cleaning the connectors with contact cleaner or isopropyl alcohol and reseating them can help.
Auf unserer Website oyostepper.de bieten wir Getriebe Schrittmotor, Schrittmotortreiber und weitere Produkte an. Wir liefern weltweit und Sie können bei Bedarf eine Bestellung aufgeben.
Napsal : 17/01/2026 3:43 am
JPMakesStuff
(@jpmakesstuff-2)
After cleaning all my connectors with IPA - I can happily report - after 6 prints now, I am not having any more problems!!!
I was experiencing the following:
 - LEDs flickering
 - tool 4 stopped extruding mid-print (but the printer would continue without error and say finished, but there would just be nothing after a certain layer where I believe the hot-end just stopped heating, or maybe the motor stopped pushing filament in, not really sure
 - some solid layers would have a terrible finish, as if it was a filament drying problem, but in reality I think there was an under/over extruding issue, which would appear and dissapear in different spots in the same print (I would always let it continue, but could never conclude it was a certain area, feature, nor the filament itself, trying new rolls, etc.)
I primarily print PETG, which on my MK4s I notice the enclosure panels get a white-ish residue on them over time, I wish someone would have pointed out sooner these connectors are getting dirty and need cleaning!
Napsal : 05/02/2026 5:51 pm
