Toolchange parameters .. single extruder MM printers - Ignore ?
Are the parameters under "Toolchange parameters with single extruder MM printers" (under Advanced - Filament settings) all useless/ignored on the multi-tool XL? It seems that should be the case as the header implies they are for the MMU, but I find no doc to state this.
I am just checking because I noticed some significant changes following a configuration update, and I want to confirm that I can ignore this annoying chunk of parameters that I wish I could hide/disable in PrusaSlicer if the case is as I expect.
Respondido : 24/05/2024 4:23 am
