Support adjustment
Warmbronner
(@warmbronner)
Miembro
Support adjustment
Better support adjustment:  Which parameters need to be adjusted on the slicer to make the supports easier to remove? I'm working with an XL.
The supports have been very difficult to remove so far and stick very tightly. Filament PLA
Respondido : 19/07/2025 2:20 pm
RE: Support adjustment
there should be a gap between supports and your model, if this is not breaking off, your filament may be too hot, and drooping to fill the gap, or your part fan may be running too slow, not cooling the filament enough to prevent drooping
or you may need to increase the top contact Z distance and the bottom contact Z distance
Respondido : 19/07/2025 9:21 pm
1 les gusta
Warmbronner
(@warmbronner)
Miembro
Thank You for your help.
Respondido : 22/07/2025 7:34 pm
