Some print heads print (intial outline) too high, then lower to print correctly (when doing infill). Nut other print heads do both at proper height...
warrenebb
(@warrenebb)
Utenti
Hi all,
I'm not sure how to address this :   (50s example of the problem video)
using : Prusa XL5IS 6.2.6.bbf   and   PrusaSlicer 2.9.4
When i print with multiple heads, sometimes 1 or more of the heads will come out and print the outer edge of the model about 2mm too high, so it doesn't connect and just lays across everything. then it will switch to the infill printing, and drop down to correct height. Other print heads will come out and do both at the proper height. So i end with a very unstable section whenever using multiple colors. (so i've started avoiding it- which negates the purpose o buying this sexy printer).
(in this case, print heads 1 and 2 seems good. but heads 3 and 4 were doing this too high thing).
I'm guessing this is prusa slicer gcode magic, which makes me give up. but maybe there is an easy/obvious fix? ideas?
Postato : 09/11/2025 8:15 pm
