Set Time without PrusaConnect
Raptor King
(@raptor-king)
Is there a way to set the time on the printer without using PrusaConnect?  The only reason I care is because the timestamp on the file is screwed up when I upload a file through PrusaLink or when sending a file through PrusaSlicer.
Best Answer by Walter Layher:
If you have a way to connect an Ethernet cable to your printer it is easy, provided you have a router with DHCP. Just plug the ethernet cable in for a few seconds and you can see that the time on the display changes. If Ethernet is not available at your location you can use a mobile hotspot and connect the printer's wifi to that. Also, just a few seconds are enough. Then you can deactivate the hotspot.
Postato : 23/04/2024 12:36 pm
Walter Layher
(@walter-layher)
RE: Set Time without PrusaConnect
Postato : 23/04/2024 1:21 pm
Raptor King
(@raptor-king)
Huh.  I have mine connected to wifi.  I'll look into why its not updating.  Thank you!
Postato : 23/04/2024 3:20 pm
Walter Layher
(@walter-layher)
Perhaps it cannot reach an NTP server because the firewall is blocking that? I am not sure if the IP address for the NTP server is hardcoded in the firmware or if any NTP server will do.
Postato : 23/04/2024 3:31 pm
Raptor King
(@raptor-king)
Thank you.  I am dumb.  I had this on a vlan that blocked the NTP server.
Postato : 24/04/2024 8:50 pm
