ripped heater plug out of Dwarf board
RD
 RD
(@rd-5)
Hi
I accidentally ripped the heater plug out of the Dwarf board, it looks like it's damaged beyond repair, but I don't know. I'm getting a new element for the heater block.
Is there a way to repair it?
Also, the little sheet metal tabs that hold it in place, is there a chance they can snap off when I reinstall this or a replacement Dwarf board?
Best Answer by Tim:
The etched circuit board is toast; a sharp technical type could maybe make it functional again with some epoxy and a few extra wires, but honestly, it is junk.
Buy a spare bracket when you order the board.
I'd also buy a new assembled heater block with element and thermistor installed at the factory. You can damage the element and the thermistor if you apply too much torque when tightening the retaining screws. Based on the connector, moving slowly and being gentle isn't one of your traits. Sorry, couldn't help myself: for what it's worth, it took me a while to figure out how that connector releases, too. But I'm experienced enough to know 'pulling a little bit harder' doesn't end well.
Opublikowany : 05/09/2025 10:31 pm
Tim
 Tim
(@tim-21)
Opublikowany : 06/09/2025 2:55 am
RD
 RD
(@rd-5)
RE: ripped heater plug out of Dwarf board
Posted by: @tim-24
You got that right! Thanks for help, and have both on the way, I get the feeling it would be good to have extras in the bin.
Opublikowany : 07/09/2025 8:40 pm
1 ludzie polubili
