Reassigning Extruders in Prusa Slicer for 3MF Files
Bradford
(@bradford)
Membre
I have some 3MF files that have filament colors arranged in different orders, Mainly because I hadn't figured out a standard yet. Now that I am starting to do more, I am wanting to avoid having to repaint all of my models, or rely on remembering to make modifications to the mapping on the XL front panel before printing. Is there a way in Prusa Slicer to in bulk tell everything that was set to Extruder 1 should now be set to Extruder 4.
To provide a basic use case. When I was starting I had Black in Extruder 1, White in Extruder 2, Red in 3, Green in 4, and Blue in 5. Now I have changed it so that Red is in 1, Green is in 2, and Blue is in 3. 4&5 change more often so I try to keep them on the less dense side. However if I open up an older file, it has Extruder 3 with Red in it mapped and set. However as the color locations have changed, Extruder 3 is now Blue. Is there a way I can easily in Prusa Slicer indicated that Extruder 3 should now be Extruder one, The idea being that Red is still printer as red and not blue.
I have done searching and have found I can do it from the front panel, but that adds another variable to the process that I would like to avoid.
Thank you forany suggestions.
Publié : 05/02/2024 11:27 pm
1 personnes ont aimé
Bradford
(@bradford)
Membre
RE: Reassigning Extruders in Prusa Slicer for 3MF Files
Anyone have any suggestions?
Publié : 22/02/2024 3:46 am
ntdesign
(@ntdesign)
Trivial if you can code e.g. very basic python. There's a conversion tool binary <-> ascii gcode in Prusaslicer. In ascii gcode you can just swap all instances of the respective tools. It would need a usable little GUI though, like the pre-print one on the XL panel.
Publié : 23/02/2024 2:47 pm
Jim Thompson
(@jim-thompson)
So much for trival.    No one wants to write code, this is an obvious oversight.  I'll enter a feature request for both the slicer and the printer.
Publié : 24/06/2024 12:06 am
SubtleSorcery
(@subtlesorcery)
Membre
I 100% have this problem and hate that we can't select which extruder goes to a multi material color without having to recolor everything. It takes me more than twice as long if I care to change it to the actual colors I want. Additionally, it starts with the first extruder and I really try and spread usage out so the nozzle wear more or less evenly. I do not want to do this on the machine. That feels open to more error than it being in the OG G-code.
If i've missed a setting, let me know! But I think I am with you on this one! 5 tool XL problems amiright?
Publié : 27/06/2024 6:44 pm
I Expect that you could use a Post Processing Script, to re order the colours within GCODE...    not sure how it would get on with BG Code
Publié : 27/06/2024 6:51 pm
Jim Thompson
(@jim-thompson)
Thank you Joan, Yes, I could, but I really don't want to write the code and add another step.   I want to import a model, fiddle with the colors, and then slice it.
The good news is the XL printer will allow you to reassign extruders at print-time to over come this, I'm just suggesting that Prusa Slicer should as well.
Publié : 27/06/2024 7:51 pm
Hi Jim does the XL Printer actually re allocate the filaments or does it just change the colour tag without changing the filaments?
Publié : 27/06/2024 8:29 pm
Jim Thompson
(@jim-thompson)
Hi Joan, Yes, you can remap tools at print time ...
https://help.prusa3d.com/article/tools-mapping-xl_668277
Publié : 27/06/2024 8:37 pm
Well I didn't know that....
I don't have an ZL to play with!
Publié : 27/06/2024 10:26 pm
flintridge
(@flintridge)
Membre
I agree, please make this a feature. We remote print Via Prusa connect and would love for it to do this and not have us save to a USB and go over load and manually pick the tool.
Publié : 31/07/2024 6:06 pm
