Puppy Error 17516 when powering up with Octoprint plugged in
Maturity
(@maturity)
I see this puppy error screen now if I power up the XL with Octoprint plugged in.  I can touch the reset button and the printer comes up just fine or I can power it on with the USB disconnected and it is fine.  Is there some setting in Octoprint or the Pi that I can change to avoid this?  From playing with the autoconnect checkbox it would appear to be due to the autoconnect at startup.  I think if there was a way to tell Octoprint to wait say, 15 or 30 seconds, after printer power on before trying to connect it would be fine.  I would like to enable the power on at upload with Octo when you do upload and print from PrusaSlicer.
Or, is this some printer firmware issue?
Opublikowany : 13/03/2024 1:47 am
Maturity
(@maturity)
RE: Puppy Error 17516 when powering up with Octoprint plugged in
So, playing around more I see that even changing the delay to connect in the TP-Link Smartplug app to 60 seconds does not help but turning this feature off does.  What a pain, why does the printer even look at the USB port before it is fully started anyway?
Opublikowany : 13/03/2024 2:11 am
