PrusaXL clogged when multicolour with many toolhead changes
DietrichJ
(@dietrichj)
Miembro
Hi
I have a PrusaXL with two toolheads. When printing with a single colour, I have zero issues. When printing in two colours, but only a single tool change, I also have zero issues. But when printing multicolour with many changes, the first nozzle always gets a clogged error. The nozzle isn't clogged, but it does make a loud skipping noise. When I unload and load the filament, the printing resumes for a minute or two. Then I get the same error. But when printing without colour changes, the error never happens. I have had this happen on two different files when doing many toolhead changes. It happens at the wipe tower. I have added a video and it happens at the end.  https://photos.app.goo.gl/76YCeiVv78NELEi69
Can you help me fix this?
Respondido : 16/05/2025 6:17 am
Pe3d
 Pe3d
(@pe3d)
RE: PrusaXL clogged when multicolour with many toolhead changes
Maybe you have to adjust the idler Pension.
https://help.prusa3d.com/article/idler-screw-tension_177367
Respondido : 16/05/2025 2:05 pm
1 les gusta
DietrichJ
(@dietrichj)
Miembro
Hi
I tried as you said, but it did not work. It keeps getting a clog error when changing toolheads a few times.
Also the filament in the first extruder always curls up as in the video below.
https://photos.app.goo.gl/aPgQaCF7MXrcgXLt9
Thanks
Respondido : 19/05/2025 9:13 am
Pe3d
 Pe3d
(@pe3d)
Maybe a clogged nozzle
https://help.prusa3d.com/article/clogged-hotend-xl_401294
You also could try to raise the temperatur 5-10°C
Respondido : 19/05/2025 4:38 pm
1 les gusta
