Prusa XL MULTITOOL - Extruder E-steps Calibration - Set different E-step values for each extruder
INVESTEGATE
(@investegate)
Hey,
how can i set different e-step values for each extruder for the Prusa XL?
Best regards
Veröffentlicht : 25/08/2023 10:57 pm
INVESTEGATE
(@investegate)
RE: Prusa XL MULTITOOL - Extruder E-steps Calibration - Set different E-step values for each extruder
UPDATE:
I figured out that its not possible to do changes via terminal to the EPROM. Maybe its because of the signed firmware. And at the moment the definition DISTINCT_E_FACTORS isnt active in the configuration.h firmware file. And if you want to compile your own firmware (custom firmwares) you lost the warranty of the printer... Not what i want 😀
I post it also on github: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3226
But it should be possible to do a custom start gcode or tool change gcode in the prusa slicer, where you can also set the e-steps for each extruder. But i dont want to experiment with it just yet. (i am not a gcode pro :D) Thats the right command for me: M92 E404.25:398.67
Maybe someone can help.
Veröffentlicht : 26/08/2023 1:31 pm
Christian Kuchnowski
(@christian-kuchnowski)
Mitglied
I figured out, that you can access an experimental menu if you choose "Settings" and than hold the Button down for a few seconds. Maybe this helps...
Veröffentlicht : 07/05/2024 1:01 pm
