PRUSA XL FIRMWARE 6.2.0
I just updated my Prusa Xl and I see new SETTINGS under the HARDWARE SETUP i.e. Nozzle size, Nozzle tool type (hardened).
Do i have to change this setting? i have a 0.4MM OBXIDIAN nozzle installed.
Napsal : 31/01/2025 2:13 pm
RE: PRUSA XL FIRMWARE 6.2.0
If you have a hardened nozzle such as Obxidian, you should change that setting on the printer, or you will get an error message if you want to print any material that the slicer flags as abrasive.
Napsal : 31/01/2025 4:50 pm
1 lidem se líbí
