Prusa Slicer XL default settings don't match the default text (hover explanations)
Ira S
(@ira-s)
I have a new 5 head XL and I'm working on getting used to it. Using the latest firmware and Prusa Slicer.
I've noticed that various settings don't match the default text (what you see when you hover over the setting).
Just a few examples under Print Settings - Multiple Extruders:
Wipe Tower is checked but the text says the default is False. Ooze prevention is checked but the text says the default is False. Temperature variation is set to -110 but the text says default is -5. Several of the parameters under Wipe Tower are also different from what the text says is the default. In all cases, the padlock (original setting) is locked.
I've noticed this is numerous places.
Have the default settings been tweaked but the explanation defaults not yet been updated, or are the defaults recommended in the text better?
Napsal : 17/01/2024 4:21 pm
