Orange clips breaking.
Robert Ringrose
(@robert-ringrose)
Membre
Each toolhead has five clips which hold the PTFE tube and cable bundle.  These clips on my 5-head XL have started breaking.  A few of them barely hold onto the PTFE tube or the cable bundle; things still work because the other clips still hold it in place.  I've noticed it since getting an enclosure, so I'm wondering if this might be temperature related and I should print them in a different material.
I've also noticed that some of the bundles lean left (towards toolhead 1) rather than being straight up, which makes them rub against each other when the low-numbered toolhead is in use.
Has anyone else here encountered this problem, and if so what have you done about it?
Publié : 12/02/2026 11:01 pm
Membre
RE: Orange clips breaking.
I have 5 and no issue with broken clips.
Publié : 13/02/2026 1:28 am
PJR
 PJR
(@pjr)
Antient Member Moderator
I have a pre-release 5T XL.  T1 bundle had started leaning well to the left, T4 and T5 bundles to the right.
I have now replaced the 3 cable strips with these: https://www.prusa3d.com/product/cable-strip/
Are your clips breaking or just unclipping?  You could buy a new set: https://www.prusa3d.com/product/cable-clip-set/ or print new ones yourself: https://www.printables.com/model/449554-xl-printable-parts/files but note that on my printer, the clips only connect to the PTFE tubing at positions 1, 2 and 5 (counting from the back).  Yours may be different.
I have not had any of the clips break, so if yours have actually broken, then that may be a manufacturing issue.  I really don't think it would be due to the enclosure.
Peter
Publié : 17/02/2026 10:44 am
