Nozzle temperature gets stuck at low temperature and not rising midprint
Arvo-Tec
(@arvo-tec)
Utenti
I'm printing with PC at 275 degrees. What happens is the print starts fine, but at 15 % for whatever reason the nozzle temperature drops to 39 degrees and just kind of gets stuck there not progressing - failing after a while of trying to raise the temperature and the print has to be stopped.
Postato : 19/02/2026 8:41 am
jan.d.slay
(@jan-d-slay)
RE: Nozzle temperature gets stuck at low temperature and not rising midprint
Have you tried moving the temperature sensor in the heat block to the location where this anomaly is observed?
Postato : 19/02/2026 1:46 pm
