Nozzle scratched my plate
BlackSmithPrints
(@blacksmithprints)
How can I make sure that my nozzle doesn't scratch the plate?
I started a new print the other day, it did the bed leveling and then proceeded to start the print as expected. However, on the first pass it made a large gouge in the plate and then the printer alerted that the filament was stuck which stopped the print. Note: The filament came out just fine on the purge right before it started printing.
I thought that bed leveling would have prevented the nozzle from going too low on the plate.
I'm running firmware 6.4.0 on a XL 5 head printer. I haven't had this issue until now. I only recently updated to this version of the firmware. I haven't used this particular head since that update but I don't know if it is related. I used a level to check the balance and it does look slightly off. Would that have caused it?
This topic was modified 4 months ago by BlackSmithPrints
Posted : 05/03/2026 4:10 pm
Racenviper
(@racenviper)
RE: Nozzle scratched my plate
You should return to 6.2.6.
6.4.0  has many issues .
Posted : 25/03/2026 9:04 pm
nrceptor
(@nrceptor)
I had this same issue with a newly installed 6.4.0 on a calibration where the nozzle dug a trench in the plate yesterday.
So how do you go back?
Posted : 24/04/2026 3:16 pm
