Nozzle is ramming into steel sheet at print start
Hello,
once again, my XL damaged my steel sheet when he print job started and the heat bed (z-axis) was moving up. I saw the nozze ramming into the sheet and it bent upwards! As if the load cell suddently was not working correctly. Just minutes before, the same tool head finished a perfect 2-hour print. Also the bed leveling of the same print worked without damage after the crash, so this is likely no hardware problem.
I saw the same behaviour from my Mini+ about a year ago. The same situation and only once. I think the firmwares are (partly) the same, so it could be a sporadic software bug?
~Zwacki
Posted : 24/05/2025 6:17 pm
