Nextruder make noises and doesn't print correctly
koelle72
(@koelle72)
Mitglied
Hello,
one of my Nextruder is making noises and the filament is not being fed properly.
What can I do?
Veröffentlicht : 18/11/2024 10:00 am
koelle72
(@koelle72)
Mitglied
RE: Nextruder make noises and doesn't print correctly
Veröffentlicht : 18/11/2024 12:18 pm
Pe3d
 Pe3d
(@pe3d)
Hi koelle72,
What Kind of Material are you printing?
Its possibly the idler tension:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/how-do-i-adjust-the-tension-of-the-extruder-idler-screw/
Make a half Turn counterclockwise on both screws and try again
Veröffentlicht : 18/11/2024 4:07 pm
koelle72
(@koelle72)
Mitglied
Veröffentlicht : 19/11/2024 8:57 am
Bane
 Bane
(@bane-2)
Hey @koelle72,
Were you able to find a solution to this? Seems my XL(2) has the same issue based on your images. Your video seems deleted from the forum, but here is mine from the clicking noise: https://drive.google.com/file/d/1mghzvCAF6W_mWJ5YKEUtXD66bKZAkDio/view?usp=drive_link
Does your nextruder make similar noises?
Thanks!
Veröffentlicht : 17/11/2025 1:18 pm
