Nextruder Cable bundle
FS5
 FS5
(@fs5)
I am having an issue where my position 1 nextruder cable bundle it leaning slightly to the left. My position 2 nextruder cable bundle is leaning slightly to the right which matches how it is supposed to look in the pictures. I made sure to position everything per the directions, but it seems like there is an inherent "memory" in the plastic piece that is causing it to lean the other way. It is causing interferences when docking and undocking each extruder between the cable bundles.
Has anyone else had a similar issue or have ideas on how to fix this?
Posted : 23/08/2023 2:34 pm
FS5
 FS5
(@fs5)
RE: Nextruder Cable bundle
**Correction**
Extruder 1 cable bundle is leaning to the right and extruder 2 cable bundle is leaning left. This is causing them to rub on one another.
Posted : 25/08/2023 11:04 pm
Dschey
(@dschey)
There is another thread about this topic of tangling cable bundles of the Prusa XL with some recommendations like replacements of the clips by improved user designs: https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-assembly-and-first-prints-troubleshooting/extruder-cable-bundles-snag-on-each-other/
Posted : 15/02/2025 12:38 pm
Pe3d
 Pe3d
(@pe3d)
You can "tune" the direction in which the cables are leaning by rotating them. Unclip the Buddyboard and Turn the cables a few Times.
Posted : 20/02/2025 6:34 am
