Modular heatbed tile alarm (firmware issue?)
Luigi Bernardi
(@luigi-bernardi)
Prusa XL - Firmware 6.2.6 - Prusaslicer 2.9.4
Started having issues with the Modular heatbed alarm. When turned on the XL boots the firmware, then, just at the end of the upload, it restarts the boot. At the end the XL stops showing the Modular heatbed tile 6 alarm. I tried the entire diagnostic procedure as from the website with no success.
The only way to use the printer is to take off the print sheet with the XL switched off. Then, after the boot procedure, which now goes on without troubles, I put the print sheet on again and I start operating the printer as usual. Just for precaution I lay the parts to be printed far from tile 6.
It seems to be some kind of firmware issue, Unfortunately I am not able to relate the beginning of the problem to a specific event.
Hope this can be of some help for others having the some problem. It might be helpful to pass this information to Prusa engineers, but I don't know how to address it.
Veröffentlicht : 19/11/2025 9:39 am
jan.d.slay
(@jan-d-slay)
RE: Modular heatbed tile alarm (firmware issue?)
Hello.
Have you tried installing the tile in a different location?
If it's always the sixth tile, try using a different one and swap them around.If the error moves with it and now ‘tile 10’ is reported, it's the tile.
If it stays, you still have the cable and the circuit board.
Veröffentlicht : 25/11/2025 6:00 am
