First layer print issues when not using tool head 1
ajcrock
(@ajcrock)
Tool heads have their offsets stored in the printer under settings / tool / tool number /  offsets.  This enables multi tools to line up with tool head 1.  But when not using tool head 1, the stored z offset creates first layer print issues.  For example tool head 3 is the only tool being used.  It has a stored z offset of .35mm.  Tool head 3 does the bed mesh and then applies the .35mm offset to the print.   If a tool head is always used by itself the z offset should be set to zero.
Complicating the matter is if 2 heads are used with each other but not tool head 1.  For example tool head 3 is the primary and tool head 4 the secondary.  Tool head 4 needs to be referenced to tool head 3.  For example if tool head 3 has a stored z offset of .35mm and tool head 4 .25mm the new offsets would be 3 and 0 and 4 at -.1mm.
Before making changes you should loosen the nozzles and retighten them using the print bed or other object to apply consistent pressure.  Then rerun the tool offset calibration.  Check all the z offsets for consistency, hopefully .5 mm or less.  Then zero out and reference heads not being used with tool head 1. Yes I reported this and showed test results.
Adjusted and referenced Z
unadjusted
Napsal : 04/07/2025 4:16 pm
1 lidem se líbí
Gregor Buehrer
(@gregor-buehrer)
RE: First layer print issues when not using tool head 1
Thanks very much for your investigation. I had a similar issue this week. After replacing the satin sheet with a new version, my first layers turned out to be too high to not sticking at all when starting with print head 2. I didn't know where the printed stores the z offset so I changed it in the print file to -0.1. I lost so much time and filament until I detected it while having a deadline in the neck. That is quite disappointing that they didn't program that one in a better way.
Napsal : 04/09/2025 7:54 am
Gregor Buehrer
(@gregor-buehrer)
Did you report it on GitHub? The issue I am having is when you change it manually for the moment, what happens when they do an update? Then the machine set up is suddenly incorrect, damaging the sheet and maybe the printer.
Posted by: @ajcrock
unadjusted
Napsal : 04/09/2025 8:08 am
johndeer
(@johndeer)
Is there any update on this issue?
I have a similar problem when trying to print with multiple colors. Is there any workaround?
Napsal : 12/12/2025 7:54 am
