Firmware (?) issue: Z axis motors go on after bed has reached bottom of printer
Hello,
I've got the 2T version and I'm starting the assembly of the 5T upgrade now. So I wanted to lower the bed to its maximum position. So, I've set a big Z value with the encoder. The distance from its current position probably meant a position beyond the actual bottom and I thought there would be some detection which would prevent the motors to go on. However it wasn't the case so I could only switch off the printer to stop the motors. There's obviously some room for improvement here.
And before you ask: yes, the latest firwmware has been installed.
Postato : 28/08/2025 8:56 am
