Firmware crashes when adjusting Z offset
Hello.
So i tried to print some TPU on my XL with 5 heads, but using only one for this print.
Whenever I try to change Z offset while printing the first layer, doesn't matter in which direction the Z goes, after about 0.200mm the firmware crashes, and everything just stops and ruins the print because the hot hotend is standing in one place.
I was using firmware 6.2.0. And PrusaSlicer 2.9.1.
After upgrading to firmware 6.2.2 and PrusaSlicer 2.9.2, the same problem occurs.
Any advice?
Thanks
Opublikowany : 16/03/2025 10:47 am
