Extruder pauses 1-2 seconds on tool change?
hyperion
(@hyperion)
I am printing multimaterial (PLA and TPU) and just before the tool change the extruder pauses over the model at the very end of the extrusion path.  With PLA this is not a big deal but with TPU it leaves a blob.  (The pause seems to occur just before the retraction command.)  I've looked through the GCode and don't see any obvious pause commands.  For other printers this appears to be related to saving data on the USB, so I tried replacing the USB stick with several alternatives but the problem persists.  The odd thing is that this just started happening, I can't think of anything I've changed.  Anyone else see this issue on their XL?
-hyp
Publié : 13/01/2025 7:08 pm
quietmesh
(@quietmesh)
RE: Extruder pauses 1-2 seconds on tool change?
I’m having this exact question and problem as well.
Like the OP I first noticed it while printing a multi color print with PLA, I was a bit annoyed about it but it didn’t destroy the print. Yesterday I printed a multi material print with PLA and TPU and the pause when printing TPU actually destroys the print because of the blob that it leaves.
I got the feeling that the “electronics” couldn’t keep up.
I’ve just purchased my XL5T in late december so I haven’t used it much yet.
I have the latest 6.2.0-RC1 fw and are pretty much using PS standard settings, I haven’t changed any start, end or any other gcode. I have no custom scripts or anything like that.
My question is if this is a gcode or firmware issue. I’ve looked at github (Buddy firmware) but couldn’t find any reports on this behavior.
Surely more people have noticed this?
I will try to do some more testing and keep a close eye on this. So far my thoughts are that it might be when I use multiple filament settings. I can’t recall this happening when I printed with PETG, but then I had the same filament settings on all tools. When I printed with PLA I had two different filament settings and of course it’s the same with PLA and TPU.
Publié : 14/01/2025 4:34 am
Pe3d
 Pe3d
(@pe3d)
You can Set the Minimum layer time to Zero. IT helped me with this issue
Publié : 14/01/2025 1:07 pm
hyperion
(@hyperion)
Thanks for the response.  Just to be sure I reinstalled the firmware and recalibrated the machine, but the behavior persists.  Good to know it is the same on the 6.2.0 RC as well, saves me the time of trying that.  I am also surprised more people haven't seen this...
-hyp
Publié : 14/01/2025 8:12 pm
hyperion
(@hyperion)
I searched for this setting in Prusa Slicer but couldn't find it, could you be more specific on where this is? -hyp
Posted by: @pe3d
Publié : 14/01/2025 8:15 pm
Pe3d
 Pe3d
(@pe3d)
Material settings (the Gear Symbol next to yours Filament settings).
Edit Presets
Cooling Thresholds
Slow down if layertime is below: 0
I`m using OrcaSlicer not Prusa. I Hope it helped!
Try Orca:
Homepage (more or less):
https://github.com/SoftFever/OrcaSlicer
Download latest Version:
https://github.com/SoftFever/OrcaSlicer/releases/latest
Publié : 15/01/2025 10:14 am
Pe3d
 Pe3d
(@pe3d)
Alternativ solution/issue:
If the Temperatur of the Extruder is not within range +/-3°C for some Seconds it will delay. Happens for me with Steel nozzles. Print settings/ multiple Extruders/ ooze Prevention
Deactivate with the risks of oozing
Publié : 15/01/2025 11:07 am
hyperion
(@hyperion)
I'm sad to report that none of these changes affected the issue on my machine.  I'm still stumped.  -hyp
Publié : 17/01/2025 5:03 am
Pe3d
 Pe3d
(@pe3d)
Go to Filament/Cooling
Untick:
Slow Printing down for better layer cooling
I would Upload a Picture but the Server wont let me.
Publié : 29/01/2025 8:47 pm
DexTech
(@dextech)
Membre
Posted by: @hyperion
-hyp
Yes, I am also experiencing the same problem, exactly as you describe it.  I am also finding this troublesome with the blob left at the pause point when printing with TPU.
I am currently running a Prusa XL with two tools, running the latest firmware 6.2.0+8816, using the latest version of PrusaSlicer 2.9.0.
I have posted a video of the pause I am seeing.  This video shows the end of a layer printed in TPU, the pause just before the tool change, and the blob that forms during the pause:
If anyone finds a solution to this, I would love to hear about it.
Ce message a été modifié il y a 1 year par DexTech
Publié : 09/02/2025 8:12 pm
Pe3d
 Pe3d
(@pe3d)
If you activate ramming it does the blob over the wipetower
Publié : 18/02/2025 6:44 pm
addius8
(@addius8)
Membre
My XL is working now in TPU Multi material mode! The pause and the blob will be printed in the wipetower, when you use the PLA Prusament preset instead of the flex preset. Im still trying to figure out, what caused the change.
Publié : 23/02/2025 10:25 am
1 personnes ont aimé
balloon
(@balloon-2)
What I did to get around this is to write a python script that comments out the G4 S1.5 commands that appear right before a tool change. There are also G4 S0 commands that really do not make sense since they are dwell for 0 seconds so I commented them out also. Now no more pauses at tool changes.
Publié : 01/04/2025 11:29 pm
mjkobb
(@mjkobb)
Posted by: @addius8
I just want to be sure I understand: you switched to using the Prusament PLA preset for the TPU, and that got rid of the pause and blob? Did you make any changes to that preset in terms of temps etc.?
Publié : 17/06/2025 8:19 pm
hyperion
(@hyperion)
FWIW the most recent firmware seemed to fix this issue, although even a few days before the release the PRUSA support team was saying there wasn't any problem.  😑
Publié : 17/06/2025 8:38 pm
mjkobb
(@mjkobb)
Oh, interesting, thanks! I think I'm on 6.2.2 so I'm a little behind. I'll grab latest. I just had this issue yesterday with a mixed PLA/TPU print on my XL. The print ended up being usable so I'm not going to run it again, but I'm glad to know that the next one should be better.
Publié : 17/06/2025 8:43 pm
