Extruder #2 extrusion issue
Rob
 Rob
(@rob-21)
Mitglied
Im having this print quality issue with my #2 extruder. I tried 3 different brands of filament with the same result. Extruder 2 had the same settings as 1 & 3. When material is moved to different extruder, print quality is good. Not sure what to check for.
Veröffentlicht : 13/11/2024 5:49 pm
RE: Extruder #2 extrusion issue
could your thermistor on extruder 2, be different?
thermistors are sensors which return a numerical value which is then converted into a temperature via a look up table. the thermistors have a tolerance and you may have samples from different batches.  I believe the prusa (semitec) thermistor is 3% tolerance so I Guess one could be 3% high and the others 3% low or vice versa, so you may have a difference of say 6%
of course if the extruder 2 thermistor is faulty, the difference could be even bigger...
could you perhaps swap the heater block with thermistor and heater between say extruder 2 and extruder 5, and see if the problem moves to extruder 5?
Veröffentlicht : 13/11/2024 6:40 pm
Rob
 Rob
(@rob-21)
Mitglied
yeah, it's worth a shot. it does look like a temperature related issue with lots of excess extrusion. my thought is that it's definitely related to either the temperature or the extruder motor not properly feeding material.
Veröffentlicht : 13/11/2024 6:53 pm
Rob
 Rob
(@rob-21)
Mitglied
It's definitely a hotend issue. The problem cleared up on #2 after the swap and followed to #5. I'm going to reach out to Prusa for a replacement.
Veröffentlicht : 14/11/2024 5:30 pm
Pe3d
 Pe3d
(@pe3d)
It could also be a problem with the idler tension. At the beginning i Had a lot of Extrusion Problems. Tried different settings. In the end my idler tension was to high
Veröffentlicht : 21/11/2024 8:29 am
Villagewolf
(@villagewolf)
Any resolution to this? Been fighting this problem on my XL for the past few days.
Veröffentlicht : 14/07/2025 9:04 pm
Rob
 Rob
(@rob-21)
Mitglied
yes, it is resolved. It ended up being a damaged nozzle. It had a crimp in it that was causing uneven extrusion. Had to look under s magnifying glass to see it.
Veröffentlicht : 14/07/2025 11:25 pm
