Enclosure Splitter board - USB C ports
floh
 floh
(@floh)
Hi everybody,
the splitter board that comes with the enclosure has two USB C ports. I've tried to connect the Buddy3D Camera there (the upper port) but nothing happened.
I'm not sure if the both USB-C ports are pass-through so I have to connect power supply the bottom port which is passed through to upper port? I don't want just try it because it could break the splitter board. So do you have idea about these ports and if we can use that to power the Buddy3D camera.
Best regards
Floh
Best Answer by martin_pihrt:
Hi, the connector on the board is through. I have a buddy camera for Prusa MK4 connected there like this (as a connector).
Martin
Ce sujet a été modifié il y a 1 year par floh
Publié : 20/12/2024 10:23 am
1 personnes ont aimé
martin_pihrt
(@martin_pihrt)
RE: Enclosure Splitter board - USB C ports
Martin
Publié : 29/05/2025 7:14 am
Jumbo
(@jumbo)
Membre
Can i use a Samsung max 25v charger as a passthrough?
Publié : 21/12/2025 12:06 pm
