E-axis stepper motor turning only one direction
layershiftingeverywhere
(@layershiftingeverywhere)
Mitglied
I had my XL printer with two heads running and had a print peel off of the plate and cause one of the nozzles to get covered in plastic.
After removing all the plastic I noticed that when I went to use unload filament on the controller I saw plastic drool out of the nozzle.
I opened the latch door and hit unload filament and the motor was turning downwards towards the nozzle instead of up and away from the nozzle to remove the filament.
I then kept the latch door open and used the move axis function for E-axis and no matter which way I turn the knob the motor only spins downwards towards the nozzle.
Is this a common issue or would anyone know how to troubleshoot this issue?
Veröffentlicht : 05/03/2026 1:24 am
Make a short video illustrating the issue then contact Prusa Support via chat and show them the file, you will need the serial number from the back of the printer.
Veröffentlicht : 06/03/2026 11:25 am
