Connect and Link both fail from anything other than Webpage
Henryhbk
(@henryhbk)
I had to do a factory reset after the whole inability to set tool offsets as instructed by support. After going through the whole setup again, I am somewhat stuck. Prusaslicer is unable to connect to the printer via either PrusaConnect or Prusalink. Weirdly the website for connect has no problem talking with the printer, and the prusa app has no problem. I went on the connect website and recopied the API key, and when I try to test the connection to either connect or link they both fail either claiming a 400 error (permission) or no-api-key which is even weirder. If the website version didn't work to upload bgcode jobs I would assume some network thing, but it works just fine, and the Prusa app on phone/ipad works fine as well. The mk4 sitting next to it has no problem from prusaslicer so not a firewall or connectivity thing. I reenabled the connection to connect via settings->network, and it said it was working. Any thoughts?
Publié : 08/11/2024 2:10 pm
