Change the extruder speed for just one Nozzle on the PrusaSlicer 2.7.1
[Solved] Change the extruder speed for just one Nozzle on the PrusaSlicer 2.7.1
Jimmy_PascalTags
(@jimmy_pascaltags)
Hello everyone, I was wondering if I could change the print speed for just one nozzle. I am printing with BVOH and PLA and was thinking about turning the print speed down for the BVOH to see if that will improve the print quality as right now there is a lot of stringing and gooing happening. I was wondering if anyone knew how to change just the print speed for one nozzle instead of the entire print? Thank You!
This topic was modified před 2 years by Jimmy_PascalTags
Napsal : 05/01/2024 4:56 pm
Frio
 Frio
(@frio)
RE: Change the extruder speed for just one Nozzle on the PrusaSlicer 2.7.1
Have you considered using the filament setting 'Max Volumetric Speed' to limit the speed based on flow?
Napsal : 06/01/2024 3:04 am
Jimmy_PascalTags
(@jimmy_pascaltags)
No I haven't! I think this should work I will try it out a little bit later on today thank you so much!
Napsal : 08/01/2024 2:11 pm
1 lidem se líbí
