Can we use White Lithium to lubricate linear rails?
3dprintingrookie
(@3dprintingrookie)
I always lubricated my Mk3 rods with white lithium but this is the first time I get a printer with a linear rail, so not sure what the maintenance procedure here is.
In the manual, it says:
Prusa Lubricant: a tube of Prusa Lubricant is included with the Original Prusa XL. It is used in the Z-axis leadscrew paragraph.
DO NOT use Prusa Lubricant on the linear rails!
https://help.prusa3d.com/article/regular-printer-maintenance-xl_401237
Best Answer by Diem:
From the paragraph below the one you quoted:
Ensure that there is no debris or dust on the linear rails. If there is, clean them using a clean paper tissue or a clean cloth with NO de-greaser and with no chemicals, as these might damage the rubber in the carriage. The factory lubrication for linear rails is effective for at least 2 years.
So, nothing for the next two years ... by then the correct lubricant will presumably be specified and available.
Posted : 18/09/2023 3:53 pm
I thuink you just answered your own question.
What is confusing you?
Posted : 18/09/2023 4:00 pm
3dprintingrookie
(@3dprintingrookie)
My question is in the title, can we use White Lithium to lubricate linear rails?
I am not sure what Prusa uses for their lubricant, so I'm wondering if the lubricant they provide is not applicable while other types like white lithium is.
Posted : 18/09/2023 4:03 pm
Posted : 18/09/2023 4:19 pm
3dprintingrookie
(@3dprintingrookie)
RE: Can we use White Lithium to lubricate linear rails?
Thank you
Posted : 18/09/2023 4:20 pm
