Can we please have an option to unload all extruders at once?
3dprintingrookie
(@3dprintingrookie)
Currently you have to apply changes for each single nozzle then apply "carry out changes". Can we just have an option to unload all?
Veröffentlicht : 21/09/2023 6:39 pm
NerdOfEpic
(@nerdofepic)
RE: Can we please have an option to unload all extruders at once?
Oooo, this!  I went from a failed 5 color print to an attempt at a 2 color print with different colors and decided to unload all the tools that weren't going to be used.  It took over 10 minutes thanks to waiting for each tool to heat up one at a time to unload.  If I could say "unload all" and have them all heat up at once even if only one gets unloaded at a time that would dramatically reduce the time involved.  A similar request for loading all tools because I don't leave filament on the printer when not in use and it takes forever to load them too.
Veröffentlicht : 15/10/2023 7:18 pm
Tobycwood
(@tobycwood)
You can always simply set each extruders temp then open up each tool’s breech, push the filament for a quick preload then simply pull it out manually.
Veröffentlicht : 31/10/2023 2:14 am
