BSOD on 2 of my first 4 prints?
bwschulz
(@bwschulz)
I've been 3D printing at home since 2016 on a QIDI Flash Forge clone and just upgraded to a 5-head Prusa XL. So far it's been a huge upgrade in every way except for software stability. My first print (the presliced Gear_Bearing gcode on flash drive) failed with a BSOD at 69%. It was garbage with stringing so I didn't try to restart it. I dropped PLA temp by 15 degrees, upgraded Prusa Slicer to 2.7.0-rc1 and my firmware to 5.1.0-alpha2 and printed a 200% articulated dragon in 3 colors and a practice gun for martial arts. Both of these printed perfectly, so I thought I was home free and tried a huge 3.5 day print, but it BSODed on me again just over halfway through. So my first question: is this par for the course or should these failures stop as the firmware is upgraded and is there anything I can do to stop it now?
My second question is about what happened when I tried to print to top of my huge print. I had to reset to get out of the BSOD screen and it didn't give me the nozzle position after it restarted, so I measured the height of the failed print and resliced to print the top with the intention of gluing it on later. When I tried to copy the gcode to the flash drive my computer said there was an error with the flash drive and asked if I wanted to repair it. I said yes and it wiped the drive. I copied my new gcode to the now empty flash drive and tried to print it, but when I inserted the flash drive the XL asked if I wanted to continue to old print. I said yes and it seems to have resumed where it left off. As a Prusa newbie, I thought all the print files were stored on the flash drive. If my flash drive got wiped how did the XL have my old print and know where to resume?
Napsal : 22/11/2023 6:24 pm
bwschulz
(@bwschulz)
RE: BSOD on 2 of my first 4 prints?
Update- The XL looks like it may be printing my newly-sliced file (which used slightly different supports) but the filename matches the original gcode file. The print time in that filename lists "3d1h22m" on the printer and in Prusa Connect but the actual print time is correctly listed at less than half that.
Napsal : 22/11/2023 7:59 pm
