[Résolu] Bed leveling problem
Tellblom
(@tellblom)
Membre
When I bed leveling now and the head is on the left back part the bed clashes I to the z-axis-bearing-holder on the left side.
After some goggling I saw someone that had a early model that had changed the z-axis-bearing-housing.stl  so I unscrewed mine and found that it is marked F1. The new one available for download is marked R5.
Anyone now if it's a difference between the F1 and the R5?
The other solution that worked for some others was to put shims under the bed holder (I.e raising the bed platform 0.5mm).
Anyone switched the z-axis-bearing-holder or shimed the bed with good result?
Best Answer by Tellblom:
Switch to th R5 z-axis-bearing-holder and it seems to work fine now.
Publié : 11/10/2025 7:02 am
Tellblom
(@tellblom)
Membre
RE: Bed leveling problem
Publié : 11/10/2025 6:12 pm
1 personnes ont aimé
