After Stopping print Extruder tries to park
jprince
(@jprince)
XL 5 tool, Firmware: 6.2.4+8909
I have found if I stop a print, and the extruder is anything but extruder #1, any further attempts to start a new print, park the "current" extruder, or even perform a reset causes the extruder to try and park in the #1 position.  While it is rare for me to stop a print, it has happened a couple times.  I further tested and can duplicate the behavior every time by stopping a print or even stopping a print while the bed is heating.
At this time, I have not tried firmware version 6.2.5.
Veröffentlicht : 30/05/2025 3:51 pm
Tüftler
(@tuftler)
RE: After Stopping print Extruder tries to park
Hello, I have the same problem with my 5T XL.This problem I had also with the FW before 6.2.5. This happened with T1,T2 and T3. The support could not help, I got only the information to use not Connect to transfer the gcode and to make a reset. All this did not help.
Did you find out any solution?
Best regards
Veröffentlicht : 07/06/2025 10:37 am
jprince
(@jprince)
I have not found a solution.
While it is rare that I stop a print, when I do it is frustrating as the head slams into the #1 slot.
Veröffentlicht : 07/06/2025 11:22 pm
Tüftler
(@tuftler)
Good morning,
here you could see the reason why I stopped the print. This happened yesterday. Then I restarted the print and it works.
But this time no crash.
Veröffentlicht : 08/06/2025 5:23 am
jbaigis17
(@jbaigis17)
Mitglied
There is a serious bug with stopping a print. It is much worse when you have enabled Complete individual objects. If you stop the print when object one is completed and it is early in object two, the printhead runs over the finished part trying to park.  I have not tested if it only tries to park to print head location one but that is the only head I've head to stop.
Veröffentlicht : 09/06/2025 8:52 pm
