After firmware update g-code error
before never had this error. after update to 6.4.0+11974
when send from prusaslicer 2.9.4 to printer error g-code not the same.
I can continue the print. but always with this error.
does anybody has this also? and how can I some this.
Postato : 11/12/2025 10:51 am
RE: After firmware update g-code error
What is at the top of the Printer tab in PrusaSlicer in your Start Code?
That?
M17 ; enable steppers M862.3 P "XL" ; printer model check M862.5 P2 ; g-code level check M862.6 P"Input shaper" ; FW feature check M115 U6.2.2+8853
Postato : 11/12/2025 11:45 am
I tried 6.4.0+11974 and it created all kinds of problems that I could not solve. Prusa support was no help either. So, I went back to 6.2.6 and everything works fine again.
Postato : 11/12/2025 10:09 pm
You can disable GCode check in the settings on the printer console. It removes the message and everything keeps working b
Postato : 11/12/2025 10:45 pm
