Advice or Suggestions on repair
phi161803
(@phi161803)
Hi. Have this weird issue with Prusa XL 5 Tool w/enclosure
I mostly print from the center of the bed. The last few prints I printed toward the rear of the print bed. I noticed alot of debris on the right side.
Then it failed to park the Toolhead 3.
I thought it might need calibration. Y calibration was fine. On x-axis calibration, this weird shaking thing happened.
A T10 also fell out from somewhere and landed beneath the print bed. I've been looking around for any missing screws and aven't noticed any. Then I noticed the belt was frayed.
Probably need to replace the belt. But would anyone have any ideas or suggestions on what should be my next steps to fix this?
I contaced Prusa support but they haven't gotten back to me yet. Probably need to replace that belt. But I am not sure why this is happening.
I also noticed that the tool holder feels like it "jumps" when moving in the x direction at certain spots (180mm - 360mm range). When this jumping/skipping occurs, the tool holder has the tendency to want to move back or forward in the y direction.
Any help would be much appreciated.
Prusa XL 5T with Enclosure
Firmware 6.2.5
Printer is about 3 months old.
Thanks in advance for any help.
Este debate ha sido modificado el hace 8 months 3 veces por phi161803
Respondido : 11/09/2025 5:58 pm
phi161803
(@phi161803)
RE: Advice or Suggestions on repair
Not sure how to upload video into post. But here is the link.
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/2e64b7d0-prusa_xl_error.mp4
Respondido : 12/09/2025 8:32 pm
Was that by email?  Use the chat function to contact support, have your serial number ready (rear of printer) and be ready to supply these pictures/videos - or direct support to this thread.
Respondido : 13/09/2025 10:30 am
phi161803
(@phi161803)
Yes, by email. They have gotten in touch with me yesterday morning. I figured time zone + other requests delayed their response. They are very helpful.
Will check out the chat function. Thanks.
Respondido : 14/09/2025 5:39 pm
siaulip
(@siaulip)
It might be that the belt is rubbing against the back of one of the tool dock supports - there is very small tolerance between the belt and the tool dock. Try tightening the bolt that holds the tool docks and fixes it to the aluminium frame - check out which dock has wear on the back.
During printing, especially with IS, the dock supports vibrate so tigthening the bolts now and then can save you a next belt. I've also noticed that there is play when the toolchanger picks up the tool - when you slightly poke the toolhead it will wobble, and that wobbliness could potentially also contribute /affect the dock support with time as it is an extra source of vibration/misalignment that can loosen up the screw with time - there's a post of a guy that has fixed the wobble by printing and installing extra washers ( https://www.printables.com/model/779361-washer) - I've installed that one and it has so far solved my toolchanger crashes 🙂
Esta publicación ha sido modificada el hace 8 months por siaulip
Respondido : 19/09/2025 10:37 am
