12 volt output
Sverker
(@sverker-2)
12 volt output
Is there anywhere that I can tap of 12V for led strips in the enclosure?
Respondido : 28/01/2024 11:41 am
Agkirk
(@agkirk)
RE: 12 volt output
I put two 12V LED strings in series and used the 24V from the power supply.
Respondido : 29/01/2024 11:46 pm
If you have cuttable LED strips you can halve your strip and wire the two parts in series.  The standard connectors are not designed to do this so some simple soldering may be necessary.
Respondido : 30/01/2024 12:06 am
1 les gusta
